Will a bicycle engine work with rear disk breaks? I would like to put the 66cc angle fire 2 stroke on my Schwinn Rivel 29er. And will it fit on this frame?
you need a tophat adapter for your disc brake. this will allow you to mount your kit sprocket to your disc brake hub and still have use of your disc brake. http://kingssalesandservice.com/category/top-hat-sprocket-adaptors/. if you check out there youtube videos andrew explains how the tophat works.
as for that frame,not sure if an engine will fit. hopefully someone else would know that would be a cool build.
