Mysterious Problem!
DeathRace
18
Illinois
I have a problem and for the life of me cant figure it out.. I had no spark after ridding in the rain and it wouldnt start up. I have replaced my plug, the wire, CDI, and magnito and it still wont start. I even disconnected the kill switch and still nothing. WTF is going on with this bike?? Any ideas???
asianflava
57
Colorado
There is always the possibility of a new part that is bad out of the box. I'd suspect the CDI since there isn't much to the plug and mag. You can test the plug wire and mag with a multimeter.
Norman
LORD VADER Moderator
Jan 16, 2008
2,606
7
71
pampa texas
use an ohm meter and check all of the wiring connections. Just because they look ok doesn't
mean they are ok. solder all plug in connections, what I mean is solder the wire to the terminal not just crimp the wire to the terminal.
Doing this will stop the ""WTF" is going on thing.
Norman
Happy 4th don't blow your fingers off when playing with explosives.
