I have a question for you Morini guys out there. I don't have a motor yet, and am looking at the Morini dimension drawing I found on the Morini USA site. This drawing gives a dimension from the center of the engine to the center of the drive sprocket of 55 mm. Using a metric tape measure I measured the engine center line to sprocket centerline of a Grubee (China) two stroke and came up with about 35mm. So that's 2.16" vrs. 1.37". Are Morini engines mounted offset to the right in the frame so you can run a typical motorbike rear sprocket and idler? I don't see how the Morini can be run on center with a standard 110mm rear frame dropout width. What's everyone doing to make it fit?
