Well I finally have my bike running again more power than ever New carb and a intake sorter manifold that Norman Made for me and it goes off to the side.
The carb exterior looks the same. The differences are that the needle is nicely tapered
and slide is made out off brass or copper and the filter is much better and lets in allot more air.
Carb is from this guy Livefast Motors: Bike Motors - Accessories
As many of you know i was going around in circles with my old carb which was missing the top tab that hold in onto the intake manifold.
I went trough HEdouble hockey sticks with this repair but I learned allot !!
a good tip is to bleed the gas line of all air, I squeezed the gas line repeatedly wile holding the filter down with my finger over the hole and the air went up into the tank now I have no air in the filter which was starving the engine of gas and I put a little wd40 on the cable to make work more smoothly.
Hopefully I will be able to use it again It's been a month since i was able to ride it to work!
Thanks again Norm!
Thanks again Norm!
