Clutch cable
jrobert1
4
Is the clutch cable the same a standard bicycle break cable? I know it may be a dumb question.
ebmvegan
283
OC, Ca
I've used the bike break cable, changed the housing to a Teflon lined housing and placed a plastic spacer in the hollow bolt. This made my clutch feel smoother and less wear and tear on the cable rubbing on metal.
Saddletramp1200
Custom MB Buiilder
May 7, 2008
1,451
83
48
Houston, Texas
If you pull the cable out of the housing (new) and coat it with grease and slide it back through it works very well. Also old cables, make a funnel out of foil and tape it really tight to the ball end of the housing and hold it upright pour a little oil in the funnel and let it be for an hour it works wonders and you don't have to remove the cable, just from the handle bar.
