vintage jc penny lightweight 5 speed
kevyleven007
1,217
8
texas
wheelbender6
4,059
221
TX
Nice build. You can sometimes get rid of the brake squeal by sanding the face of the brake pads. If that doesn't work, new brake pads should fix it (old pads lose their flexibility, which leads to squeal).
kevyleven007
1,217
8
texas
yeah,I replaced two of them and it didnt help.its not too bad though and it stops good.never tried sanding them I will give it a shot,Thanks
NunyaBidness
1,062
memphis tn
The angle of the pads as the touch the braking surface will also make them squeal. they should be slightly 'toe in', meaning the front of the pad should contact the brake surface first but not by much.
kolbpilot
34
USA
A little late to this topic but I found sanding (scuff 'em up) with a light grade paper the contact area (side of the rim) of the wheel where the brake pad rubs against. Worked on my squealing Huffy.
