Chain tensior/ gear slippage suggstions
copmagnet80cc
84
Ohio
I was riding my motorbike today and I was riding for nearly an hour when my motor chain had begun to slip and hit my spokes on my rear tire and busted about 5 or so spokes. I know im going to buy a new rim but does anybody have any suggestions on what I should to to keep this from happening again.
Ive heard of half links so I don't have to use the tensioner Ive also seen the spring tensioners and such alike but I don't know what is a for sure guarantee . But I would like to keep this on a low budget as possible. Thanks all:-||
xseler
2,886
151
OKC, OK
If your chain was loose enough to come off/slip as you call it, half links are of no use.
Remove enough links so the chain has just a bit of 'flex' in it and use one of these....
http://motorbicycling.com/showthread.php?t=48647
As long as everything is aligned, you should have zero issues with this setup as long as you keep your chain lubed.
Good luck!!
