so I have the GT5 grubee with the NT carb. I have the SBP shift kit. when i start pedaling it fires up and seems like it wants to go when i give it a little throttle. but then dies... so i put it up on a rear axle stand to troubleshoot. I kicked down on the pedal and it started right up!! idle was good with cluch engaged and dis-engaged. And i always get them confused with which position the clutch lever is engaged and disengaged. So with the clutch lever released.... my back tire would spin at a low speed. when i tried to force it to stop, the motor would die.
1. Why is my back tire spinning with no throttle?
everything seems to be running great when the rear tire is off the ground...
2. So why when i get it moving forward it dies with a little throttle?
Float position is good. idle is perfect. fires easily, thus the kick start...
Im soo lost...
Any ideas
Im soo lost...
Any ideas
