I need to order a replacement chain for my kit. My cruiser's tire size is 26x2.125 Going to order the #415 heavy duty chain. I think I read somewhere that the chain might rub one the tire. Is this the right chain to order? Other chains? Thanks
The #41 chain is the super wide super heavy duty chain, 415H chain has a thinner more "normal" width but has heavy duty plates and should be plenty strong. #41 runs fine for me, but it is wide, it would be the more likely chain to rub. If your kit chain clears the 415H should clear for you as well, the #41 needs a little extra clearance...I need to order a replacement chain for my kit. My cruiser's tire size is 26x2.125 Going to order the #415 heavy duty chain. I think I read somewhere that the chain might rub one the tire. Is this the right chain to order? Other chains? Thanks
The chain the came with the kit did clear the tire(barley). So the #415H would be the right choice. Tried ordering the chain from gasbike.net but the chain specs says its for 4-cycle engine or newer grubee engines. Mine engine kit is a 2011 grubee. Will the #415H work on my 2-cycle engine kit. ThanksThe #41 chain is the super wide super heavy duty chain, 415H chain has a thinner more "normal" width but has heavy duty plates and should be plenty strong. #41 runs fine for me, but it is wide, it would be the more likely chain to rub. If your kit chain clears the 415H should clear for you as well, the #41 needs a little extra clearance...
