oil mixture
headtrama
886
16
california
What oil mixture is everyone running . I'm still breaking my motor in on a 32:1 mix what should i mix it at after the break in .
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
If all seems well at 32:1...leave it alone. That is a good compromise between the recommended 24:1 and some of the exotic synthetics. I'm one of those Opti-2, 100:1 weirdos but I do not recommend it to everyone. Use a good quality 2 stroke oil formulated for air cooled engines and you'll be fine. Check your spark plug color occasionally. Good luck, ride safe.
Pablo
Dec 28, 2007
3,696
33
48
Duvall, WA PNW
www.sickbikeparts.com
Anyone ever jet one of these motors.what is the stock jet size mine seems to run a bit rich .
Yes they are rich from the factory. 0.70mm is stock size.
Jets can be had at SBP.
I run 32:1 pretty much always, and in my gallon is always 3 oz synthetic oil (I like Amsoil Dominator) and 1 oz castor oil to make the 4 oz.
headtrama
886
16
california
I moved the needle down one notch and the bike is running good.The four stroking went away and it accelerates great now and seems to be running way better.
MotorNut123
220
New York
im braking mine in at 35:1 and im gonna switch to 32:1 after break in. thats what everybody seems to be running. i havent touched the c clamp at all. it runs fine. idles nice and everything. im not that worried about it because this winter i will be getting an addon racing carb and slant head from zoombicycles.
GearNut
5,104
11
San Diego, Kaliforgnia
Woah! Aaaack!
Break it in with 20:1 or 24:1.
If you break it in with 35:1 the poor thing will not get enough lube and you will do internal damage; to the piston, cylinder, potentially overheat the rings, and possibly gall the bearings.
MotorNut123
220
New York
really? mines perfect running. me and my friend both broke it in with that and there is no problems at all. should i go to 24:1 for a gallon and then switch to 32:1. i was thinking about doing that.
MotorNut123
220
New York
yea im gonna run a gallon or so of 24/1 and then switch to 32/1. thanks for telling me, and im glad my motor is great even though i used that mixture!
MotorNut123
220
New York
well i mixed up a gallon of 24/1 and took it for a ride. its running good and feels like a smooth ride. im gonna do another round of break in with this mixture then go to 32/1.
