Schwinn Chopper suzuki fa50 runs slow at times?
TheSignGuy
459
9
seattle, wa
Hi, so my fire up process worked out good starts on first kick everytime as of now I would like to figure out why my FA-50 IS laggy at times, I can pull the choke in or out at times and it speeds up by its self, the main focus here is that on a concistancy level fastest I've got it to go would be 20mph at lowest speculated before rigging a new brake cable up was 8-15 in the past few days of ownership I am aware the carb looks like **** but is fairly clean enough if it starts first kick everytime.
Some other notations I have taken in concideration as listed.
• fuel petcock (suzuki fa 50/honda____/yamaha qt50 pw50) not sure what is the full off position on it says on, pri, and res which in short for On postion, reserve position, and prime.
• The drain line has a slight very very slow drip when off (suspected leaky or dirty float needle).
• too much vibration on crappy roads (no shocks what so ever) (decrease tire pressure)?
• no kill switch
Any ideas why and how to fix these issues?
I don't think I'm running rich but do need an air filter once in a blue moon it smells a tad bit rich but not screaming rich to where it burns anyones eyeballs always good to run a hint rich only run 50:1 synthetic high quality tru fuel as it's an old used engine I don't think it's ever been rebuilt either.
I detest disassembling the carb as well as it still starts good but I do need to figure out what's wrong.
