chain question
wan37
354
Illinois
I have a stock 415 chain that is new with a 66 cc kit and it's got some stiff links.I saw it somewhere in the forums soaking might help.So what oil do I use or any other ideas for me to do? Thanks
GearNut
5,104
11
San Diego, Kaliforgnia
The stock chains are junk, pure and simple.
You are better off getting a quality 415 or 41 chain from Tractor supply, Ace Hardware, ect.
The biggest reason why the stock chains have stiff links is due to bent side plates or poorly riveted link pins. You might be able to work the offending link(s) loose by prying the side plates apart a teeny little bit with a couple of screwdrivers, ect. If the problem is a bad link pin you will have to work the chain back and forth over and over until it wears loose.
Plan on replacing it soon anyways.
fugit
176
Oregon
KMC 3/16" 415 TRIKE & INDUSTRIAL 110L BLACK
Search Item number 261002571550 on ebay
5.94 + 6.00 shipping good deal good chain
