longest ride u have taken your motorized bicycle on
NunyaBidness
1,062
memphis tn
Re: longest ride u have taken your MB on
A friend and I rode to his Mothers house and then from there to the other side of the lake she lives on, where his grandmother lives. So between 50 and 60 miles round trip.
scotto-
Custom 4-Stroke Bike Builder
Jun 3, 2010
6,505
24
Ridin' inSane Diego, CA.
A couple months back I did 2 round trips that totaled 110 miles in 1 day. That's the most in one day that I can remember and I was actually a little sore the next day as I did it on a rigid bike.....no suspension on my cruisers.
dnut
Cogswelln
207
Maine
the furthest round trip for my trike 14 miles, for my regular mt bike it was 20 miles round trip. the difference from going to my cusins or the warf
210Don
15
San Antonio
I've done about 34+- round-trip. My first trip, i didn't have a derailleur so i had a ton of chain slap and my tire would grab the chain and pull it off the sprocket, it was pretty dangerous. I installed the derailleur and the second trip was smooth. The only issue i have now is not being able to fully disengage the clutch as the carburetor on my china girl impacts with the clutch arm. i plan on bending it so it clears... any other suggestions on that?
baadboy
90
tulare cal
got a pic that dont sound right 4 the clutch hitting the carb
mapbike
5,502
109
Central Area of Texas
If your clutch arm is hitting the carb. before it clutches the engine you have either major wear on the flat surface of the clutch camshaft that pushes the bucking bar inward to disengage the clutch or the bucking bar itself is wore on one or both ends.
I say pull the clutcharm/chain gear cover off and inspect the lower part of the camshaft to see if it has a groove wore in it where it contacts the bucking bar and if not then take th bucking bar out and look to see if the 8mm ball bearing that it rides against have dished out the center of the bar, if it has then go to the local Tractor supply or hardware store and get a bolt that is either 5/16 or 8mm in diameter and about 3 inches long so it has an area between the threads and the head of the bolt that is long enough so that with a hacksaw or other means of cutting it you can use a piece of the unthreaded section of that bolt to make you a new bucking bar by cutting a section out of it that is the same length or maybe even a few .001's langer than the original bar.
I have done this on one of mine and it makes a better bucking bar than the ones that come in these engines in my opinion.
One or both of these two things I discribed here are likely your problem/ or problems from my experience.
If you need a clutch arm camshaft Piston Bikes has it here for $3 Motorized Bicycles Gas Bike Engines Gas Powered Bikes Motorized Bicycle Parts
They also have the new bucking bar for $4
I dont understand the bucking bar costing $1 more that the camshaft which is machined to make verses the bucking bar just being a piece of junk round bar that isnt normally even cut true on the ends......... but anyway I say check these points and I'll bet you find your problem.
Good luck, Peace
