sproket adapter
heyscuba
64
st. louis, missouri
I"m having a problem in this area,...
e-mail me if you can help,...
First off, the sprocket doesn't fit over the hub assembly,
I'm making the hole bigger now by slowly reaming it out with a Dremmel,
but I fear once I get it to fit over that part IF I put that outer (thick) rubber washer on the wheel and then the sprocket on it will all stick out to far and I will not be able to put the coaster brake bracket into it's slot if supposed to fit into.
[email protected]
