Alright I am working on setting up a motor for a Bianchi San Jose model I have. I have a normal flipflop hub already on the bicycle and I am wondering is there any company that sells a reverse ratch-ing freewheel or a fixed wheel that I can bolt a larger sprocket to. I know that is a lot to ask, but I figured this is the best board for this kind of question.
What type of engine and mounting system will you be using?
You need a wheel hub which will accept a left-hand threaded freewheel, such as this:
http://www.staton-inc.com/Details.asp?ProductID=2769
You also might want this larger sprocket which bolts onto the left-hand freewheel:
http://www.staton-inc.com/Details.asp?ProductID=3570
For a cheap fixed-wheel setup, you could use the ragjoint connector and sprocket, which comes standard on Happy Time engine kits.
Or you could have an aluminum sprocket adaptor made by Creative Engineering...
Or you could buy a disc brake wheel hub and machine your sprocket to bolt onto that...
or buy the "top-hat adaptor, which bolts onto the disc hub and #35 sprockets...
Or find sprockets which bolt directly to disc brake hubs:
http://www.electricscooterparts.com/sprockets.html
These sprockets use the smaller #25 chain found on Staton's new axle-mounted kits:
I'm presuming that you COULD machine #35 or whatever sprocket to bolt onto the left-hand threaded freewheel.
