I purchased the higher compression Head model A-2B from
Zoombicycles 80cc Slant Cylinder Cover (A-2B) | Cylinder Parts | Parts and Accessories | EHBC Distributors Ltd
I did see an Improvement. I did notice at least 15-25+% Increase in Stronger take off power. Low, mid and high range power with higher RPMs. I have a SBP Shift kit so I can keep the RPMs down.
Sick Bike Parts
I also Have a SBPs Expansion chamber pipe,
Sick Bike Parts
and a Boost Bottle from boost bottle industries.
I also used this product from reading a tread on this forum!
Permatex Copper Spray-A-Gasket Hi-Temp Adhesive Sealant
Fast-drying, metallic copper sealant helps dissipate heat, prevents gasket burnout and improves heat transfer. Fills minor surface irregularities. Seals instantly. Fills hot spots and surface imperfections. Temperature range -50°F to 500°F (-45°C to 260°C); resists all types of automotive fluids, especially gasoline. Level 3*
Suggested Applications: Cylinder head gaskets, carburetor gaskets, exhaust manifold gaskets rubber seals and other high temperature applications.
I used this on the head gasket works great. Also to seal a leak from the rubber seal on the crank shaft behind the magneto or magnet.
Worked great. Very Satisfied!!!
