Suggestions for 4-stroke motor mount for OCC Stingray?
AmericanGasBikes
24
Cherry Valley
A person recently approached me wondering if there are motor mounts for 4-stroke kits for the OCC Schwinn stingray. I've looked around online and obviously found nothing. I've seen a couple photos of other's Chopper builds with 4-strokes installed, but couldn't see what method others were using to install the kit.
Any Suggestions?
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Build a mount similar to the HT mount but install a flat plate on top rather than ht mounts.
AmericanGasBikes
24
Cherry Valley
@maniac57 Thanks for the tip
@bigbutterbean As a matter of fact I did. For future reference though I had to inquire myself, in case someone else asked later.
Much obliged fellow Motorheads!
chainmaker
2,634
69
48
Ma USA
A piece of flat plate welded to the bottom tube will be fine. You will run into chain routing issues if you are keeping the pedals unless it's a small 4 stroke like a HS
