I did search and did not find this question posed exactly this way, but if I didn't search well enough forgive me. I am building my own lighting system (hi/low beams, turn signal, brake light, running lights) plus horn, planning on using 12v SLA to power the system and ebay white wire charger. I have yet to have found a straight answer as to whether a battery can be charged and used at the same time. If I hook the white wire charger eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices directly to the battery and my lighting system to the battery, would not the light/horn system wind up bypassing the battery and drawing from the magneto wire, most likely drawing too much current and messing up my spark? My goal is to have the charger charge the battery and while it's being charged, the battery to run my lights/horn. I was considering a 2 battery system whereas 1 battery is hooked to the charger and the other, previously charged battery is hooked up to lights/horn, and when that gets depleted, to switch depleted battery to charger and previously charging battery to lights. This is not my 1st choice due to expense of batteries, plus added space used and weight. They do make fairly small, inexpensive SLAs but if it could be done with 1 battery that would be ideal. Do any of you have experience with this? Thanks in advance for any insight. Obviously I have none but the most basic understanding of circuitry but one way or another I'm sure I can make it work.
