with the walbro carb you are not dependant on a float boal it has an internal pump so you can mount it upside down if you wanted and it would runn fine !!! also its a butterfly carb so i would imagine instant throttle responce like a weed wacker or chain saw has !!! and also it is has fully adjustable needle jets so you can fine tune high and low by simply turning a screw !!! no more swapping jetts!!! to top it all off it comes with a velosity stack and high preformance air filter and a RSE reed block and billit addapter !!!!
i bet this setup would blow away any deltoro or cns carb !!! h#ll man i could run my motor upside down in a tight motorized bicycle frame if i wanted !!!
anyone runn a setup like this or know of someone who does please let me know about your experiance !!!
i know about the quality of this high end carb i had a few on some built up chain saws that my dad put together and manthey realy did run any way and the responce from them was insane instant throttle !!! i also know that the pocket bike guys run this carb and love it !
i want to know if it will work out for our motors and if anyone has or is running one. because even if it didnt out preform the deltoro but was on par with it, it would still be worth the extra cost just for the sheaar fact that you can fully tune it with 2 screws and never have any jets to mess with ! and it does not need to sit lvl and can run in any possition !
