Here is a gas tank that will just about fit into a worksman or other straight bar frame. Will work well for a board track racer. It measures 16" x 3 1/4". It has a screw on cap and a 1/4" fitting on the bottom. It appears to be nickle plated copper. It has no leaks and is real clean on the inside. It does have some scratches and dings. It will hold a 1/2 gallon.
With just a minor notch in the top bar it will fit right into the worksman frame.
$100 shipped in the lower 48 gets you this wonderful tank.
PM me if you want it. Thanks,
