Where can I take my motorized bike for repair or tuneup around town??!!
fistfulofsuss
16
Treasure Coast
Have several problems that I just can't figure out or do myself, any recommendations?? Also, would be willing to pay anybody that's local and that could help out, thanks......
reg454
269
michigan
any local mower repair shop should be able to do it they work on 2 cycles too. my dad and i used to work on mowers and 2 cycles what are the symptoms these motors are simple and their are a lot of knowledgeable people here that can help you out.
matt167
420
usa
yup.. there no diffrent than the most basic 2 stroke weed eater.. even a dirt bike shop, as there closer design to them
Cabinfever1977
2,288
Upstate,NY
did you push the primer button 3-4 times then try and peddal the bike 100 feet @ 10mph, then release the clutch and keep pedaling until it starts then pull in the clutch and idle it with some throttle to keep running.plus the choke lever should be in up position when starting unless its real hot outside,then leave lever down.also is you gas petcock in the on position.
