I just finished installing a clutch actuator I got from Creative Engineering/Manic Mechanic. The clutch seems to work ok as far as disengaging and the start of the engine is actually a lot smoother now.
(Kudos to Jim for his great work!)
The problem is I seem to be having problems with the throttle again. The clutch seems to work fine: when I disengage it, the engine starts to turn over. This works, but twisting the throttle doesn't seem to engage the engine.
I can hear revving sounds inside the engine as if something is happening, but this isn't increasing my throttle at all.
I went through all of the standard steps in starting an engine, I even tried to start going downhill. The engine seems to turn over fine, but no luck with the throttle.
Might something be loose in the carb? Do I need to check the cable connection on the twist throttle handle?
Other than change out the clutch, and rewire the factory kill switch, I've not made any modifications to the setup. The engine was working just fine before this. I had no problems with actually running the bike.
Here's my setup: standard 48cc HT kit on a schwinn point beach. I spliced the black wire of my kill switch with the black wires from the CDI and the engine. I wired the yellow wire of my kill switch to the blue wires of my CDI and engine. I capped the white wire coming out of the engine.
Adjusting the choke seemed to have no effect on this throttle problem. The cable seems to be pulling correctly on the stuff inside in the carb, but for whatever reason, it's not engaging the throttle.
My engine eventually comes to a stall on me.
Any help with the troubleshooting would be much appreciated.
Thanks in advance!
Thanks in advance!
