A few pics of my unpainted, and yet to be perfected front wheel drive bike!
Check this out,it may help you. just remember that with a front mounted engine,error margin....mmmm... does not exist and it can get nasty very quick. enjoy.http://motorbicycling.com/f36/front-mounted-minimoto-engine-16978.htmli agree with both of you, it's a little scary. I only droveit once so far, my chain became loose, by pulling the front wheel upward on the slots i made for the axle. Also it was too high sped and had too little power on take off. i have used this motor before on a friction drive bike i built, and it has the power. The centrifugal clutch has 12 teeth and the wheel sprocket is 48. I thought this would work well, because i was comparing it to the two cycle kit bikes. My kit bike had a 44 tooth rear sprocket and 10 up front. I was however led to believe that the kit bike was revving up much higher than it was. Using the gear index calculator provided in this forum, i now realize that the two stroke 66 c.c. kit bike never even hit 2000 rpm. no wonder i got away from that junk. my briggs should rev up around 3000 plus. Anway i will need a bigger sprocket, much bigger. The forks have been reinforced though i kept the weight down as much as possible. the wheel may look a bit rusty but the spokes are tight as is the bearings. Also though you cant tell from the pic, i raised the front end to help put some of that weight onto the back wheel. im not crazy about this build but it did help me practice some welding which is the main purpose i had for building it. i really want to build a bike with a custom frame, i'm just playing around to see how things work before i buy any square tubing to build a custom frame. this bike was all made from scrap as you can tell lol.
