Whilst trying to find an elusive air leak. I gave up and decided to fix my clutch that was starting to slip, when I took the cover off it was covered in black oil, so I found my air leak as well, so I took the small gear off and sure enough the seal wasnt pushed into its casing properly, and the crank is bured whitch is why the gear allways protruded a bit, and the screw holding the gear in was hard to remove like it was crosthreaded. my question is what normaly holds that seal there or is it just pressed in or was it the gear not seating properly . As I havnt reasembled it yet.
