J joey2point0 New Member Aug 17, 2011 3 0 0 Wisconsin May 8, 2013 #1 Hey Guys, I FINALLY Completed my motor bike and couldn't be more pleased, I basically started from a bare metal frame and built it how I wanted it. Attachments test2.jpg 819.8 KB Views: 220 test.jpg 287.6 KB Views: 156
wheelbender6 Well-Known Member Sep 4, 2008 4,059 221 63 TX May 8, 2013 #2 Wow. You really dressed up the cables and wiring. Where did you end up mounting the coil?
J joey2point0 New Member Aug 17, 2011 3 0 0 Wisconsin May 8, 2013 #3 Thanks! I really wanted a clean look. The coil is attached to the front motor mount, I drilled and taped a hole on the mount part and put a bolt through it. Since I have heat wrap the coil stays at a fine temperature.
