I'm going to have one bulletproof wheel!
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Check this out:
Scored from a super HD trike rim that got wasted and replaced.
HUGE spokes and nipples MAKE ME SMILE!
Just so happens I have a bare drive hub laying around waiting to go into rotation....
This is going to be the heaviest, most bulletproof drive wheel I've ever built and should be super sweet.
I like super fat nipples and big 'ol honkin' spokes!
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Still have to drill out the rim for the HUGE nipples, but I'm halfway done!
STOCK
DRILLED
CHAMFERED
LACED (1/2WAY)
This thing is gonna be a TANK!
maniac57
Oct 8, 2011
4,484
22
memphis Tn
It was a Tomahawk Industrial trike made here in Memphis.
Spokes are about 8 guage. Original hub and wheel had been drilled by hand and not even de-burred. Very rough and tons of burrs on both rim and hub.
This only took a few minutes longer, so I'm guessing the factory simply didn't care.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
This rim is on hold awhile since I want to run the outstanding little Runtong motor I scored recently and ported.
But I get bored late at night so you never know!
curtisfox
6,046
3,948
minesota
8 guage Big spokes, Must no long be made can't find anything on the net.Should be one tough wheel. Thanks..............Curt
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Okay. here's the latest.
Spokes are about 1/4" too long and won't tighten up. I'm bummed. Need a different hub or a die to thread them a bit more.
I also might try adding washers and see if that does it, but I'm not optimistic.
Wheelzilla is on hold pending new developments or a threading die.
If you look close at the bottom pic, you can see how the huge nipples stick out (lol) and won't tighten enough to tension
frank66
207
canada
maniac that rim is single walled. on elexpress there are some mag wheels maybe worth a try if they are cheap.
maniac57
Oct 8, 2011
4,484
22
memphis Tn
I have not given up yet. Looking for the correct die to thread the spokes a bit more. Won't take much to allow this hub to work correctly.
