I thought I'd start a thread on polishing up old aluminum drum brake hubs. Not that I really know anything about it. I'm hoping that others will contribute their knowledge and share it here. I like drum brakes. I like the way they look, especially on a vintage bike, perhaps a tribute board tracker or anything going for the early motorcycle look. Whenever I run across an old one I salvage it figuring at some time or other I may end up using it.
I have others in my treasure trove besides the ones pictured below. I've used new Worksman and Sturmey Archer hubs, but when I can I prefer to use one's from mopeds which are often very well made. The Worksman hub is the wimpiest I have used. Atom hubs made in France are pretty darned good and I'm looking forward to using some bigger ones in hopes they will give even better stopping power.
Pictured below are a pair from a Honda 55 trail bike (the big hubs) and the smaller pair are Atom from an AMF moped. The AMF had a wimpy friction drive motor, so the sprocket pictured is for the right hand side and hooked up to a standard pedal sprocket. I'll use the Atom pair on a 1951 Schwinn cantilever framed bike which will be powered either by a 5 horse Briggs following the lead of MSRFAN or a 212 Predator. I want it to be belt drive, so the Atom hub will be perfect since I don't need a left hand side sprocket.
The bigger Honda hubs are intended for a much modified AMF moped frame with a Tomos moped engine. The pedals are part of the low slung engine so there is no need for a right side sprocket. Kick backwards on the pedal and it starts the engine. With the lighter bike and two speed tranny it should be a pretty fast bike. That's why I'll use these bigger hubs. Also the front hub has a wide axle, so it will fit the Suzuki K-10 suspension fork which has a wide spacing between the legs. A stock Worksman or Sturmey Archer hub will not fit the Suzuki fork. So this is why it is nice to have a small pile of old drum brake hubs to sort through. Also of course, the price is right on a salvaged hub. I only save out hubs with 36 holes for the spokes. That way I can lace them into 26" rims and use 11 or 12 gauge spokes to make a nice wheel for not much money. The most expensive things are the spokes.
The down side in using old hubs is they usually look pretty bad, all oxidized and dirty. Cleaning them up is a chore as I have done it in the past with fine steel wool. Tedious. I decided the other day there must be a better way. So, I picked up a cloth buffing wheel and small container of Mother's Mag & Aluminum polish to see if it will make the job go a little better. You can see on the front Honda hub that I have done some initial cleaning on it with a pad of fine steel wool.
The only experience I have had before in polishing aluminum was with a sidecar made from an aluminum Grumman canoe. My friend Steve saw me laboring away with fine steel wool and handed me a container of Mother's to try. A little on a rag did wonders compared to the steel wool, so I'm hopeful about the hubs.
What I have for equipment is an electric washing machine motor with an arbor on it that I use with a wire wheel for cleaning parts. I'll remove the wire wheel and attach the cloth buffing wheel and go from there.
Now what? How would you go about this? Any suggestions? What do I do when the cloth wheel gets loaded up with polish/metal black gunk? Do you wash it or something?
I'll be working on these hubs in between other things and when there is progress I'll post photos showing the results. I just want them to look good, not like chrome or anything. I'm counting on some good advice here which we can then share with everybody. Thanks in advance,
SB
SB
