I have a 4 stroke motor, the exhaust is 7/8" like a 2 stroke exhaust. But I want to use a 5/8" square pipe for a custom exhaust. I cut off the end of the 7/8" pipe that attaches to the motor, and welded it to the square pipe then bent the square pipe. Will it damage the motor or make it run bad? Or will it be ok?
Basically what I need to know is, will using a pipe that is slightly smaller than the usual exhaust pipe cause a problem with the motor? It is only a 2/8" difference.
