Just finished this one up to the ride stage. Wanted to build an ultralight weight, but bad weight management got me. Came in at 49lbs, was shooting for the low 40s. I weigh 170, so the AUW is not too bad. This is my first HS/Grubee set up. For the most part I like it. Geared like it, is tops close to 35. Was amazed at the power the little HS has. Will pull off pretty easily from stop(though I normally pedal it off), and once rolling the accleration is amazing. Most of the build is welded, mounts etc. Certainly not a looker, was built for function and reliability and to be an every day rider. Should look ok when painted though. Plan to ride it all summer to shake it out and paint it this winter.
