My motor has been slumping to the left some. Broke a chain, figured I'd fix it. Pulled the clutch cover off to make a like shaped, vertical engine mount. Something that bolts over the outside of the cover, goes up and bolts to the top tube.
After getting the cover off, I noticed rings ground into the cover. With my clutch lever pulled and the back wheel off the ground, the wheel does not spin, if the chain falls off it does spin.
Thoughts? Advice? I made this alum gasket. Gonna leave some meat on it for now, in case I wana bolt some thing to it. I'll pretty it up later.
I'm thinking of making a new front mount that extends up to the top tube. be more attractive.
