Poo Poo pipe modification
93KHJFRK
11
The OC
I just ordered a Poo Poo pipe and as it turns out, the left crank hits it and the pipe will have to be bent inward. I've read that these pipes can break easily. Should I heat the area with a propane torch to bend it? Thoughts?
Thanks,
Mike.shft.
Humsuckler
457
Ontario
heat, and heat for at least 10 minutes.... bend gently. steady pressure. be careful you dont bend it too cold or you will break it
