Take the plate the clutch arm is in off. Leave the clutch push pin and bearing in the clutch shaft. Rotate the clutch arm till it will slip out of the housing. At the bottom there's a flat in it. Take a dremel and round off the back edge of that flat. Not to much just radius it. If you hold it with the flat end pointing up it's the right edge. That's the edge that pushes the clutch pin. Put a little grease on the whole thing and put it back together. It makes the clutch pull alot easier and smoother.
