Red tank(white pinstripes?) for sure, seat can hide under your butt. I'd at least do your removable covers white. But if you wanted to go all out, maybe white bbq/engine paint on the jug/case?
That should keep you busy enough for the snowy months ahead
How's she running btw?
having an issue with the engine making a squeeling sound as the sprocket turns... I've put the clutch in after start to see If i hear the sound, and i do a tiny bit, more so when the clutch is in and pulling me... it squeels for afew seconds I guess until it heats up then stops the sound, then it sounds fine..
I gotta work on it, probably follow norms thread, but time is so tight for me... I haven't riddin the bicycle for a few days now because i'm worried about that squeeling sound. plus I think I have to change the gasket on exhaust pipe because I've noticed leaking on the engine, burnt oil runs down my engine, think it's spraying because the gasket needs to be changed...
my big worry is the sound of that squeel....
I'll try to give more detail, possible take pictures and photo circle what I mean and where the problems happening. I'm not knowlegable enough to fix these by myself, thats why this site isthe BOMB.
