Hey Guys,
I was riding my bike and heard an awful metal ringing like banging metal from my engine. I stopped and checked out basically nothing (I'm an idiot for not walking it home, which was 500 ft away, and taking off the head).
Here is what I found after riding without hearing the noise again, since I didn't check the piston cylinder until last night. I had dents all over the head and top of the piston. I figured out that a metal rod forced itself into the top of the piston and that's why the noise stopped. I pulled the rod out and realized that I can fit a paperclip all the way through the hole, which means it would not be a pressurized combustion chamber. I filed the little metal rod, which I think came from the spark plug, and jammed it back into the hole so that I have a flush fit with the top of the piston.
I realize this is probably not that safe to continue riding on. The cylinder walls do not really have any scoring, by the way - so I want to know from you guys this:
If I buy a new piston and head, will that work or have I done too much damage? Check out the attached picture, which was taken before I filed down that protruding rod (filed away from the engine - not in the cylinder). I'm not a broke college student, but close to it. Let me know what you think...I appreciate any advice you can give me!
This is the piston I would buy to replace my damaged one:
http://www.ebay.com/itm/221289988397
