piston question
dob1385
new mexico
this is my first post, excuse me if i mess up terribly.
Anyways, I have a skyhawk engine from jake's. it has 40mm intake and exhaust
spacing. It also has a 40mm stroke making it a 68 point whatever cc. it came
with a Z-L rod and what appears to be a skyhawk piston (10mm wrist pin. 7mm
from skirt to pin. 12mm long skirt with about 24mm between skirt cutout. I would
like to get a new piston. Will the number 5 piston work? who sells original grubee
skyhawk pistons? the only place i found was custommotoredbicycles.com
any help or info would be very appreciated, thank you
crassius
4,032
158
USA
I've gotten them from mzmiami on ebay - they usually ship a #2 or #3 oversize
dob1385
new mexico
so the number 5 won't work? the only number 2 I have seen is for 50cc. what is meant by oversize
thank you for your response
crassius
4,032
158
USA
I measured many years ago and found the each number stamped on piston equals 20micrometers oversize, so a "1" is about .0008in over & "5" is about .004in over.
They aren't model numbers or part numbers.
dob1385
new mexico
thank you. so it is more a measurement of machining tolerances, correct. I just noticed that certain vendors: bike berry, gas bike, custommotoredbicyles, referred to pistons by a number. I've seen number 2,4 and 5. thank you again this has been most informative
