carb hitting the frame
So I bought and installed the carb spacer kit for the NE5 engine. When I got the Whizzer, I thought the carb looked a little too close to the frame, and I *thought* that the spacer would actually provide a little more clearance, along with it's other benefits.
Attached are pics. You can see a little rust spot on the frame where the cable nipple used to be rubbing the frame; but you can also clearly see that the lid on top the carb is touching the frame. Not shown is the cable getting bent over against the bottom of the tank.
Anyone else have this issue, and if so, how to fix? I can't really lower the engine because the rear mount is fixed. So I think I can only rotate the frame. And I think rotating the engine down will make matters worse?
