$5 LED Strobe Light / Flasher at Wal*Mart
rohmell
1,531
6
New York
Here's a variable-rate flasher/strobe using LEDs available right now at Wal*Mart for $4.97!
Batteries included!
Comes with a locking stand that can be used as a mounting bracket.
Change the LEDs to high intensity red for use as a rear flasher.
It can be found in the Halloween section.
Here's a quick video I made of it:
ImageShack® - Online Photo and Video Hosting
( I don't know if this post belongs here in the Lighting and Electrical section, or in the Swap and Shop section)
rohmell
1,531
6
New York
Cool!
Five bucks, how can you beat that!? I will have to go back to the store and get a few more.
Maybe even power them off of the white wire from the engine...
rohmell
1,531
6
New York
It uses three 1.5 volt cells, so it runs on 4.5 volts.
The potentiometer control only offers a variable flash rate.
I took a look inside, and it has a little PCB with two or three transistors on it, so it' would appear to be a simple flip-flop circuit with the LEDs hung off one of the transistors. The four LEDs are wired in parallel.
It could easily be wired for constant-on operation by bypassing or eliminating the PCB and connecting directly to the LEDs via a current limiting resistor.
