disappointed with my cns carb
hcrft
28
NORTH CAROLINA
my schwinn is destined to have a performance carb, boost bottle, nitrous, a tuned pipe , and shift kit. i decided to start with a cns carb. IT SUCKS. the only time the bike makes any real power is right before the engine runs out of fuel. otherwise, if the fuel valve on the tank is open, the engine is flooded, and bogs down when i open the throttle.if tried all the obvious combinations of needlevalve settings, fuel settings (from rich to lean), covering or uncovering the two tube ports on top of the carb, and the results have been different variations of the same problem.im going to go back to the stock carb, and if the jet in the cns carb is bigger than stock, i will swap them. SO DISAPPOINTED in the carb!!
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Yet another person who did not know what they were buying, just heard "FASTER!!!"
The CNS needs to be tuned to work right by someone with some understanding of exactly what a carb does and how adjustment changes things. You should read up on tuning these carbs here in the forum before you get mad. There is plenty of information if you take the time to learn and you will surely have much better results than just bolting stuff on and nailing the gas....
There is no such thing as a free lunch.
Greg58
5,353
2,575
Newnan,Georgia
The cns needs the float set correctly to compensate for the carb angle, if yours runs better right before it runs out of fuel try bending the float tang to close the needle sooner. As for the jets they are not the same thread size as the nt.
