re-purpose old leather belts
christopher fowler
105
p a washington
I have been using old leather belts between motor mount and frame as a way to isolate vibration. Very old school and it looks cool,+works well to compensate for frame to mount gaps.
Motor Boys
179
Cambridge
Hey Chris can you post a pic, I would be interested in seeing what they look like before I cut up one of my only 2 belts, (for some reason I keep out growing them, He LL maybe it's form only using my motor) :)
silverbear
The Boy Who Never Grew Up
Jul 9, 2009
8,325
670
northeastern Minnesota
On my current build, a 39 Elgin, I used scraps of elk hide cut to size for the mounts and used contact cement to glue them directly to the mounts beforehand. Now there is no scraping up the new paint while fitting the motor. It worked very well and will do it on all future builds.
SB
Cabinfever1977
2,288
Upstate,NY
I used pieces of rubber from my old rubber handle bar grips and taped them under my mounts with black electrical tape,works great and still holding up.
happycheapskate
1,989
Rockwall TX
I'll keep it in mind, but I like tingly toes, so I just mounted mine straight to the frame via the rear clamp and a bolt through block for the downtube.
Ulysys
59
Spokane, WA
I did something like that on my bike, but I used some scrap leather a friend of mine gave me, maybe 1/8th inch thick, and I cut pieces large enough to wrap around the entire frame tube. Filled the gap I had on my rear mount pretty well, but I almost wasn't able to get the back from clamp to fit over the mounting studs enough to actually hold :). Also, once the leather compresses a bit, it will give the mount some nice grip on the frame.
christopher fowler
105
p a washington
i am stoked to hear this tip being aplied and working well!
Ulysys
59
Spokane, WA
One thing to remember, is that when the leather compresses, it's a good idea to check the nuts on the mounting studs to make sure they are still tight. Mine loosened up a little over the first week, partially due to the leather compressing, and partially because the nuts had loosened up some from vibration, even with loctite :).
happycheapskate
1,989
Rockwall TX
Leather dries up, shrinks and cracks, if exposed to heat, prolonged intense sunlight, stresses, or volatile chemicals. If it works for you great, but you may have to replace the leather pieces sooner than metal or rubber shims.
Sharksfan
135
San Jose, CA.
Thanks Christopher,
I tried this when I put my engine back on after some repairs and the difference was very noticeable. Thanks for the great tip.
Sharksfan
135
San Jose, CA.
thanx for kudos sharksfan happycheapskate made a good point about checking bolts regularly till leather is compressed completely!
I have tried to be pretty thorough about my bolts considering it was a broken motor mount stud that had me taking the engine off in the first place. I was using pieces of an old tube before and I think that is what started the failure in the first place.
