motor running ruff
decou23
12
saint charles, mo
2 stroke, 32/1 mix, barely broken in runs ruff during normal riding like on a flat road but under straine like running up hill it smothes out and runs fine weird right any ideas
2door
Moderator
Staff member
Sep 15, 2008
16,302
175
Littleton, Colorado
We need more information. 2 stroke or 4? New engine or broken in? What fuel mix ratio are you using? Give us something to work with and we'll try to help you out. Its hard to diagnose problems unless we know what we're looking at.
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
First off... you should break it in with 2 gallons of 24:1 mix.
The engine will start to run better & better the more it breaks in; I usually tell people not to start worrying about how it's running until they've run about 4 gallons through it! ;)
yamahonkawazuki
137
Clinton Tn
i broke mine in a ( BGF) at 16:1, going great now. roughly 17 miles inher. maybe more, most of which at speed, and pulling hills too. BTW what size engine, also when was last time you changed plug?
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
That's called "4 stroking" and is normal to some degree with a these.
It's cause by your mixture (fuel to air) being a little rich. Get a tank or two through it, and then try moving the C clip up one notch on the slide needle.
Actually, it's about right when the engine breaks back and forth between a 2 stroke (loaded) and a light 4 stroke at cruise.
