Anybody else having as much trouble with this build as I am? I finally got the Barrys motor mount rebuilt so that the motor kinda fits it, then I got the mount put on the frame. The instructions said to mount the bottom plate so that it butts up against the welds on the seat tube. It should have said to butt it up against the seat tube even if you have to relieve it to make room for the welds or you won't have any horizontal adjustment because the front motor mount nuts will hit the downtube. Then I spent some time elongating the holes in the sprocket and grinding down the rear hub so it would fit. I just put the carb on and there really isn't room for the cables under the top tube, not sure what to do about that, maybe one of those offset intake tubes. I'm starting to dread even thinking about the gas tank. Maybe the first two builds I did spoiled me. If I ever get this done I hope it's a lot of fun to ride because it's sure been a PITA to build.
