Builds FYI Clone/Honda 4stroke ATV/Pit/Dirtbike 50cc Engines
Crazy Horse
Dealer
Feb 20, 2009
1,153
36
USA
For those of you interested in this type of Stretch Cruiser & Chopper Motorized Bicycle Build with a chinese clone / horizontal Honda 50cc-110cc 4-stroke, ATV / Dirtbike / Pitbike engine, well this thread should get you started.
This thread could be your favorite FYI / Build info Link, for most any question related to these type of builds, I've put as many of them together that I could find, thereby saving you many headaches of searching and posting a new thread needlessly, If you know of others that are related to chinese clone / horizontal Honda 50cc-110cc 4-stroke, ATV / Dirtbike / Pitbike engine builds using a Stretch Cruiser or Schwinn OCC Stingray Chopper or XL Chopper or any Custom Built Chopper let me know and I'll add them to this already growing Build ( FYI ), Information List !
Here's a few links for Stretch Cruiser & Chopper builds using the chinese cloned honda crf type 50cc-110cc horizontal 4-stroke ATV / Dirtbike / Pitbike type engines.
http://motorbicycling.com/showthread.php?t=22533
http://motorbicycling.com/showthread.php?t=19630
Peace Crazy Horse.
If you'd like to view more pic's of these style builds then checkout my photobucket page just click on the below Link.
Image hosting, free photo sharing & video sharing at Photobucket
DingleberryPie
7
Pittsburgh
Thanks Crazy Horse,
I was interested in such a motor I was wondering is it possible to modify the sump so this engine can be mounted at a 45 degree angle in a standard frame?
thanks
Crazy Horse
Dealer
Feb 20, 2009
1,153
36
USA
Please Notice this thread is to help builders contemplating this type of build, and to offer quick links to other forum members posts of their completed builds.
Whatever style you choose be it a Stretch Cruiser or a Schwinn Stingray OCC Chopper or the XL Chopper ( XL= Adult Sized Chopper ).
Please do as much research as possible before attempting this type of build, read our forum members threads about their builds of this style and type, it'll save you many headaches in the process.
Here's the build list of engine & electrical parts & components with the prices, and the picture of what you might need, you may not need everything on the list for your engine.
Item Id Name: 名称 Description QTY (pcs/set) Price(/PC) QTY
MC-56-50-04-01 HEAD LIGHT ASSY 前照灯总 0 $35.00
MC-56-50-04-01-01 BULB 灯泡 GB/T15766.1 35/35W 12V 0 $7.00
MC-56-50-04-01-02 BULB 灯泡 GB/T15766.1 W5W 12V 0 $3.00
MC-56-50-04-01-03 HEAD LIGHT GROUPWARE 前照灯组件 0 $35.00
MC-56-50-04-02 R.FR.TURNING LIGHT ASSY 前右转向灯总成 0 $20.00
MC-56-50-04-02-01 BULB 灯泡 GB/T15766.1 R10W 12V/10W 0 $5.00
MC-56-50-04-02-02 R.FR.TURNING LIGHT GROUPWARE 前右转向灯组件 0 $20.00
MC-56-50-04-03 ALL THREAD HEXAGONAL BOLT 全螺纹六角螺栓 GB/T5781 M10*45 0 $1.00
MC-56-50-04-04 PLAIN WASHER 平垫圈 GB/T97.1 Φ10*20*2 0 $1.00
MC-56-50-04-05 STANDARD PATTERN HELICAL SPRING LOCKWASHER 标准型弹簧垫圈 GB/T93 Φ10*16*3 0 $1.00
MC-56-50-04-06 HEXAGON NUT MODEL 1 1型六角螺母 GB/T6170 M10 0 $1.00
MC-56-50-04-07 BRACKET,HEAD LIGHT 前照灯安装支架 0 $10.00
MC-56-50-04-08 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M8*25 0 $1.00
MC-56-50-04-09 HEXAGON NUT MODEL 1 1型六角螺母 GB/T6170 M8 0 $1.00
MC-56-50-04-10 L.FR.TURNING LIGHT ASSY 前左转向灯总成 0 $20.00
MC-56-50-04-10-01 BULB 灯泡 GB/T15766.1 R10W 12V/10W 0 $5.00
MC-56-50-04-10-02 L.FR.TURNING LIGHT GROUPWARE 前左转向灯组件 0 $20.00
MC-56-50-04-11 WIRING BOX 电器件盒 Ⅰ 0 $15.00
MC-56-50-04-12 CROSS RECESS PAN HEAD BOLT 十字槽盘头螺钉 GB/T818 M6*12 0 $1.00
MC-56-50-04-13 PILOT LAMP,HEADLIGHT 大灯指示灯 0 $10.00
MC-56-50-04-14 METER ASSY 仪表总成 0 $80.00
MC-56-50-04-15 NATURE DISPLAY LIGHT 空档指示灯 0 $10.00
MC-56-50-04-16 WIRING BOX 电器件盒 Ⅱ 0 $20.00
MC-56-50-04-17 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6*12 0 $1.00
MC-56-50-04-18 STEADY REST,WIRING BOX 电器件盒固定支架 0 $10.00
MC-56-50-04-19 IGNITION SWITCH LOCK 点火开关锁 2档4线组合插 0 $18.00
MC-56-50-04-20 FAUCET LOCK 龙头锁 0 $15.00
MC-56-50-04-21 RELAY 继电器 LY 0 $25.00
MC-56-50-04-22 RECTIFIER 调压整流器 4线组合插 0 $20.00
MC-56-50-04-23 C.D.I.IGNITER C.D.I.点火器 0 $20.00
MC-56-50-04-24 HORN 喇叭 12V/1.5A 105db 0 $15.00
MC-56-50-04-25 IGNITION LOOP ASSY 点火线圈总成 0 $25.00
MC-56-50-04-26 SINGING SPARKING RELAY 闪光器 0 $18.00
MC-56-50-04-27 DIODE 二极管 YIN XING DE45 0 $15.00
MC-56-50-04-28 RR.BRAKE LIGHT SWITCH 后制动灯开关 0 $10.00
MC-56-50-04-29 COVER,BATTERY BOX 电瓶盒盖 0 $15.00
MC-56-50-04-30 STEADY REST,BATTERY 电瓶固定支架 0 $15.00
MC-56-50-04-31 STORAGE BATTERY 蓄电池 XDC 12V/4AH 120*70*90 0 $65.00
MC-56-50-04-32 SPEEDOMETER LINE 里程线 930 0 $18.00
MC-56-50-04-33 MAIN CABLE ASSY 主电缆总成 D17F2 $60.00
MC-56-50-04-34 PROTECTOR TUBE 保险管 0 $3.00
MC-56-50-04-35 ANODE WIRE 正极线 350 0 $4.00
MC-56-50-04-36 R.RR.TURNING LIGHT ASSY 后右转向灯总成 0 $20.00
MC-56-50-04-36-01 R.RR.TURNING LIGHT GROUPWARE 后右转向灯组件 0 $20.00
MC-56-50-04-36-02 BULB 灯泡 GB/T15766.1 R10W 12V/10W 0 $5.00
MC-56-50-04-37 TAIL LIGHT ASSY 后尾灯总成 0 $25.00
MC-56-50-04-37-01 TAIL LIGHT GROUPWARE 后尾灯组件 0 $25.00
MC-56-50-04-37-02 BULB 灯泡 P21/5W 12V 0 $6.00
MC-56-50-04-38 LICENSE LIGHT ASSY 牌照灯总成 0 $20.00
MC-56-50-04-38-01 LICENSE LIGHT GROUPWARE 牌照灯组件 0 $20.00
MC-56-50-04-38-02 BULB 灯泡 GB/T15766.1 R10W 12V/10W 0 $3.00
MC-56-50-04-39 L.RR.TURNING LIGHT ASSY 后左转向灯总成 0 $20.00
MC-56-50-04-39-01 L.RR.TURNING LIGHT GROUPWARE 后左转向灯组件 0 $20.00
MC-56-50-04-39-02 BULB 灯泡 GB/T15766.1 R10W 12V/10W 0 $5.00
Just match the part number with the picture, yes it's as simple as that see the pic below.
Maybe you'd like to see a picture of the engine components well here it is, I've included the price's for each part, remember you may not need some of these parts for your build, this is meant as a FYI builders source.
Here's the part numbers and price list below, again just match the part number below to the part number in the picture above.
MC-56-50-05-01 ENGINE ASSY 发动机总成 0 $350.00
MC-56-50-05-01-01 STATOR LOOP 磁电机线圈 2极 0 $45.00
MC-56-50-05-01-02 SENSOR,GEAR DISPLAY 挡显传感器 0 $10.00
MC-56-50-05-01-03 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6*30 0 $1.00
MC-56-50-05-01-04 COVER,CHAIN OF ENGINE 发动机链盖 0 $30.00
MC-56-50-05-01-05 ALL THREAD HEXAGONAL BOLT 全螺纹六角螺栓 GB/T5781 M6*8 0 $1.00
MC-56-50-05-01-06 CLIP,FR.SPROCKET 前链轮卡子 0 $8.00
MC-56-50-05-01-07 FR.SPROCKET 前链轮 420 13齿 0 $15.00
MC-56-50-05-01-08 STARTER ASSY 启动电机总成 0 $45.00
MC-56-50-05-01-09 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6 0 $2.00
MC-56-50-05-01-10 SPARK PLUG 火花塞 GB/T7825 ATRTC 0 $7.00
MC-56-50-05-01-11 CLUTCH ASSY 离合器总成 2片 0 $65.00
MC-56-50-05-01-12 KICK STARTER LEVER ASSY 启动杆总成 0 $20.00
MC-56-50-05-01-13 ALLMETAL HEX FLANGE LOCKING NUT 全金属六角法兰面锁紧螺母 0 $1.00
MC-56-50-05-01-14 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M8*104 0 $3.00
MC-56-50-05-01-15 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6*22 0 $1.00
MC-56-50-05-01-16 INTAKE ASSY 进气管总成 0 $18.00
MC-56-50-05-01-17 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6*25 0 $1.00
MC-56-50-05-01-18 INSULATOR 隔热板 0 $10.00
MC-56-50-05-01-19 ENGINE GROUPWARE 发动机组件 50CC.国际档,手动离合,4个前进档 0 $350.00
MC-56-50-05-01-20 GAUGE,OIL SEAL 机油 0 $10.00
MC-56-50-05-02 MUFFLER ASSY 消声器总成 0 $85.00
MC-56-50-05-02-01 HEXAGON NUT MODEL 1 1型六角螺母 GB/T6170 M6 0 $3.00
MC-56-50-05-02-02 GASKET WASHER USED FOR MUFFLER 排气垫 GB/T3452.1 Φ24*32*5 0 $10.00
MC-56-50-05-02-03 MUFFLER GORUPWARE 消声器组件 0 $85.00
MC-56-50-05-02-04 ALLMETAL HEX FLANGE LOCKING NUT 全金属六角法兰面锁紧螺母 GB/T6187.1 M8 0 $1.00
MC-56-50-05-03 ONE WAY VALVE ASSY 单向阀总成 0 $25.00
MC-56-50-05-03-01 HEX FLANGE BOLT INCREASE SERIES 六角法兰面螺栓加大系列 GB/T5789 M6*12 0 $1.00
MC-56-50-05-03-02 ONE-WAY VALVE GROUPWARE 单向阀组件 0 $20.00
MC-56-50-05-03-03 SPRINGINESS LATHE DOG 弹性卡箍 KG Φ17 0 $1.00
MC-56-50-05-03-04 BREATHE TUBE 通气管 Φ15*41 0 $6.00
MC-56-50-05-03-05 SPRINGINESS LATHE DOG 弹性卡箍 CB/T679 Φ15 0 $1.00
MC-56-50-05-03-06 AIR FILTER 空气过滤器 0 $10.00
MC-56-50-05-04 CARBURETOR ASSY 化油器总成 PZ19 0 $45.00
MC-56-50-05-05 ANCHOR EAR 抱箍 Φ40 0 $4.00
MC-56-50-05-06-01 SYPHON, AIR CLEANER 空滤器弯管 Ⅰ 0 $8.00
MC-56-50-05-06-02 SYPHON, AIR CLEANER 空滤器弯管 Ⅱ 0 $6.00
MC-56-50-05-06-03 AIR CLEANER GROUPWARE 空滤器组件 0 $20.00
MC-56-50-05-06-04 AIR CLEANER SPONGE 空滤器海绵 0 $15.00
MC-56-50-05-07 CROSS RECESS PAN HEAD BOLT 十字槽盘头螺钉 GB/T818 M6*12 0 $1.00
Note: You can also shop around for the part you need and look for a better price, now that you know what to look for!
If you have found a source for any of these parts please post it in BarelyAWakes thread http://motorbicycling.com/showthread.php?t=19630
Peace Crazy Horse.
P.S. If you haven't figured it out here's the Roketa website Link below contact them for the parts listed above:
ROKETA,atv, exercise & fitness,dune buggies,scooter,gokart,dirtbike,moped,utility vehicle,motorcycle,electric&gas scooter,water craft,golf cart,bike,quad,offroad,motorsport,jet, sand rails, moped, snowmobiles,helmet,accessories,generator,porcelain do
I always try to suggest if you want a complete package, that is a engine that has all the above components ready for installation on your build, and you want to save some $$$ just search around for a kid's 50cc-110cc ATV you can find them new with prices starting around $399.00 here in the USA
Crazy Horse
Dealer
Feb 20, 2009
1,153
36
USA
Dingle, you probably could modify this engine to sit at a 45° angle but personally I wouldn't recommend tilting this engine for aesthetic reasons ie it would look hideous tilted. Just my opinion!
Let us know how it works for you, just curious!
Peace C.H.
Thanks Crazy Horse,
thanks
