hello,
i have a home built ebike with a brushed 36 volt, 600 watt crystalyte front hub mounted motor. i recently burned out my controller when i hooked up my 3 12volt batteries to it.
here's my question: regarding the wire coming out of the hub motor. i touched my ohmeter's lead to it and the other lead to the bike frame. it showed continuity proving that the wire going into the hub motor was grounded. it is a single wire with two terminals and both terminals are grounded to the bike frame.
is that normal or is there a short or ground somewhere in the hub motor and was that the cause of my controller burning out? i don't want to spend almost $100 for a new controller and have the new one burn out again as soon as i connect it.
anyone know how that double wire leading into the hub motor should read when using an ohmmeter?
thanks in advance,
david
valparaiso, in
thanks in advance,
david
valparaiso, in
