Ok so I have a 80cc engine kit that I bought from ZoomBicycles, It was the cheapest kit I could find and that's all i really look for when I buy a kit. The first time I took off the head of the engine I noticed that 2 of the M8 studs came out of the crankcase rather than the head bolts coming off of the studs. I do a lot of tinkering with my engines and the second time I took of my head I stripped one of the holes in my crankcase. Thank god for Heli-coils i repaired that and ran my engine again. About a Month later i decided to add a thinner gasket below the cylinder, and guess what, another hole stripped in my crankcase.
Ok that cant be a coincidence. I inspected the studs further and realized that the threads are different on each side. The side made to go into the engine is an M8 coarse thread, and the side made to accept the head bolts is a M8 fine thread. But the most ridiculous part is that the head bolts are made for M8 coarse threads. The Head bolts were basically forced onto the studs cutting new threads into them, so you are forced to either cross thread the head bolts onto the studs every time, or to remove the studs from the crankcase.
I know these engines aren't made to be the most quality pieces of engineering but the wrong threads?! I don't even see how it would save money to do this.
Honestly, i want to ask for my money back but Ive had the engine for 2 months now, so all I can do is complain to you guys.
I ordered some M8 coarse threaded rod to replace the studs, in the meantime avoid ZoomBicycles or make sure that you got the right studs/bolts with your kit when you get it.
