The diameter of my bike frame is just a bit too small to keep the tensioner in place. It keeps moving around, causing the chain to pop off, or bind up. How bad would it be to take a few links out of the chain and run it without a tensioner?
Norman FYI a lot of the model car paints are very close to bike colors. I matched my huffy and a couple of mountain bikes fram colors up that way. Your local hobby shop should carry a good selection also the testors paint at walmart matches up at times too. Just a suggestion.I like your bracket for your chain tensioner ought to be bullet proof.
My biggest problem is finding paint to match the bike if I weld on it. If I can find the right color paint the 2 bikes that I mounted the front engine bolt through the frame will get a tube reinforcement welded in when I can find the proper color even with the drilled frame I have not had any problems.
Norman
I like it Tom! Not only will it be bullitt proof it will also add some strength to the back of the Jaguar. I hate the looks of the kit tensioner so I always machine my own out of aluminum and split them so they are the exact dia. of the chain stay. I think I will use your idea on my next bike!If you're building a Schwinn Jaguar you have to do something to keep the chain adjusted. The Jag has no provisions for moving the rear wheel back. The dropout is just that, a dropout without a slot. I've always hated the looks of the kit supplied tensioner bracket. It's an eyesore and I didn't want one on the Jaguar so I fabricated the one pictured below. I made it from 1" by 1/4" flat stock, machined a slot in it and tig welded it to the seat and chain stays. I found matching paint at the hobby shop, Tamiya #TS-53, model car paint, and repainted the welds after smoothing with some body filler. I use skateboard wheels for pulleys. This set up assures that there will be no movement of the pully and should provide a troublefree way to keep the chain adjusted. I've only needed to tighten the chain on my old bike once in 700 miles but even so it's a good feature to have available.
Norm,I like your bracket for your chain tensioner ought to be bullet proof.
Norman
I've designed a 'tensioner-less' chain tensioning system for HT (all without a roller tensioner.)
QUOTE]
What you are speaking of sounds like witchcraft. I'm very curious.
