ok i took the bike for ride and stopped for a few minutes, then started back up and it was hard starting. then a minute later the engine just stopped running. ive been racking my brain since on what could be wrong. heres a list of the things that ive tried.
1) checked spark. seems to spark well and consistently
2) checked fuel, seems to be putting out sufficient fuel because its spraying out the exhuast on the exhaust stroke
3) checked compression and it seems to be compressing pretty good
4) replaced the head gasket
5) tried 3 dif spark plugs
6) check all the ignition wires
7)removed exhaust to see if it was clogged (still no start)
8) removed air cleaner to see if it was clogged (still no start)
9)sprayed starting fliud in the intake while cranking (i have a pull start)
it popped once but didnt stay running for any amount of time
took the cylinder off to see if the case might be full of gas but it was empty
10) checked base gasket, checked head gasket seemed decent shape with
no leaks
11) using a 32:1 mix havent done anything different as far as gas mixture goes
12) took the carb apart to check the jet and float, everything seems ok
13) checked the top of the carb and the throttle still ok
i havent put the cylinder back on yet, the case gasket looks wet but i cant tell if its from the inside or leftover from the exhaust dripping out while testing it. it seems like the case gasket it still good though
i read some other threads on here and used some of the suggestions with no luck. anyone have any ideas for me to try? should i make a new case gasket anyways? i really dont want to break this engine all the way back down again but i will if i have to.
any help will be appreciated thanks.
no leaks
