yup thats right !! i got myself a honda cb200t for free !!!
the bike was my sisters learning bike about 15 years ago, back then i swapped the rear sprocket out from the stock one that was around 45t to a huge 60t sprocket so the bike would not go so fast when she was learning to ride. the bike drove just fine for years, after she learned to ride, i modded the bike into a make shift dirt bike so she could learn to trail ride.... this involved swapping the tires over to dirt bike tires and adding larger break rotors and a better rear suspention. she off roaded with it for a few years on the weekends for some time...
then the bike sat out side under a metal tin roof pannel, it sat for nearly 10 years.....
well i walked by it and took a look... it had roots comeing out the ground and into the frame !!! LOL trees were growing into it !!!
i hacked all the trees away and pulled the clutch in and rolled it out to the field. once out in the field i gave it a slow kick to see if she would turn over, and to my suprize she does !!! ... now i know this thing will not start nd even if it would i would not risk it with old gas and oil in the lines !
the thing is it a vintage bike and it turns over and has all the parts and the frame and body and motor are in good shape !
i know if i bring this to my lil shop i know for a fact that i can tear it down to nothing and start from scratch... hone and deck the cyclinder, new high comp pistons, port and polish, new valve job and valves, new midrange cam, mabey a set of larger carbs, and a new strait pipe dual exhaust .
of course would go through all the electronics too..
my idea is to rebuild it into a high prefomance mini motorcycle with pedals !!!! i will probably use the frame and motor and not mutch else LOL i want as little electronics as possable sort of a mini chopper bike street legal with a set of pedals for the heck of it. i will remove any and all things that are not nessary to lighten it up or mabey i will use a big strong beach cruiser bike frame and do a biuld off that
IDK but i know i want it to run again and its my new prodject !!
here are pics of the exact bike and some pics of what i might do with it !!!
it is a twin cylinder 200cc 5 speed !kick start and electric (may remove the electric start to reduce wieght and uncomplicate things)
