The clutch gear might be too loose and rubbing against the clutch gear cover
How is the clutch otherwise? Does it seem to grab in proportion to your throttling and engine revs?
You probably need to take the cover off and tighten the flower nut in the middle of the clutch gear-
first remove the set screw-
if it moves easily
tighten it so there's at least a little resistemce on the nut and put the set screw back in
I;m thinking it could also be too tight- if it squeals MORE as it heats up it may be too tight and grabbing more the pads as they heat and expand
you may even have to repeat this a time or two
I've got a motor where the clutch has kept needing adjustment - and I still don't know why
but it was rubbing on the cover- not squeeling- but noticable metallic noise, and even wore a groove in the middle where the flower nut is
got that stopped but the stupid thing needs adajusting too frequently
