Hey all, I come for your help again after searching through countless threads about drive sprocket covers, bucking bar and bearing, clutch adjusting etc but I was not able to find a solution.
Ok how it started was I purchased a 415 chain for my grubee from thatsdax since they fit the piratecycles sprockets perfect. Forgive me for I am a total newb. I could not fit the chain on the drive sprocket so I removed the drive case and drive sprocket (instead of removing master link and feeding the chain through..dumb I know). I remvd the nut that holds the drive sprckt and used the sprckt removal tool. I was able to take it out fit the chain and install it back on no problem using a mallet to tap it back in. Now the bucking bar sticks out a 1/2" (with bearing still in it of course) and cannot fit the drive case back on flush. I did read its only supposed to stick out a 1/4". And I did adjust the flower nut on the clutch side. Pardon if I shouldn't have done that...
What should I do? Thanks, Josh
