I'm trying to repair/replace a centrifugal clutch for a hoot gearbox that came with the 49cc 4 stroke engine kit that I purchased from Daemonbikes a 1.5 years ago.
The bolt holding the centrifugal clutch onto the crankshaft came loose as I was riding, the clutch came off and wedged against the clutch bell. One of the clutch pads was worn down on one side.. After taking everything apart and putting it back together it works fine until I start it up and then the clutch dislodges and wedges against the clutch bell.
I think this problem will be resolved if I can:
1. find a place to obtain a replacement pad
2. find a place to obtain the same centrifugal clutch
3. find a replacement centrifugal clutch that will work with the hoot gearbox
Has anyone had this problem or know of a place to find these replacement parts? The only thing that seems to be a problem is the worn pad.
Thanks!
Thanks!
